BAT
May 8th, 2007
Hello I'm trying to use bat to add phone and user. When try to create a csv file i do not have execel on the call manager can use, and i do not want to use notepad is anything elese i can use to get this done
Brandon Buffin Tue, 05/08/2007 - 07:14
  • Purple, 4500 points or more
One option is to create the file on a machine with Excel and copy it to the CCM server.
Brandon
joe2065 Tue, 05/08/2007 - 07:16
how to create the csv file please explain thanks
joe2065 Tue, 05/08/2007 - 07:43
it does not say how to create the csv format, mac addrss, dn
Brandon Buffin Tue, 05/08/2007 - 07:54
Under the section Phones and Users combination, it gives the mandatory and optional columns and gives an example. I am attaching a sample CSV file with all fields used for Phones and Users. You can edit it with Excel or Notepad.
Brandon
