ACS 4.0 Supplementary User Info fields.. Can it be extracted?
May 8th, 2007
I use ACS 4.0 and have used the Supplementary User Info fields on users accounts to create a Staff Number field under each uers account. I have a requirement to extract this from the ACS internal database but the csutil.exe doesn't seem to do this when I do a -d. Has anyone encountered this before and can show me the light?
RS
darpotter Mon, 05/14/2007 - 03:19
  • Silver, 250 points or more
Yes, aaa-reports! can import the ACS db. Once imported there are canned reports on its content. Also our query builder allows you to search/filter/group/export the user data.
The trial version allows you to import 50% of your groups & users.
Darran
