7911/7941 Ringlist.xml without CallManager
May 8th, 2007
I have one 7911 and one 7941, but i haven't CallManager.
I'm using SolarWinds.net TFTP Server for upload new ringtones to the phones. There are two archives in the root directory of the tftp: Ringlist.xml, looney.raw
The file Ringlist.xml contains:
<CiscoIPPhoneRinglist>
<Ring>
<DisplayName>Looney</DisplayName>
<FileName>looney.raw</FileName>
</Ring>
</CiscoIPPhoneRinglist>
The phone gets the ringlist.xml file, but then the display shows the next message: "Bad Ring List File!"
What can I do?
I repeat, i have not a CallManager.
europesip Tue, 05/08/2007 - 07:51
It's solved. I have used "CallManager Simulator" like a tftp server.
europesip Wed, 05/09/2007 - 07:09
There is any way to solve this without use CallManager or CallManager Simulator?
