2950 Linked to Net but can't ping
ankbhasi Tue, 05/08/2007 - 08:33
  • Cisco Employee,
Hi Paul,
When you say you connect your desktop it is effectively off the network? Can you confirm if the link light comes up? Can you confirm what is the ip address you assigned to your 2950 switch?
There are many things to start from. So ca nyou post your "sh run" and "sh vlan" and same for "4006" switch also. Looking at the configs of both the switches lot of things will get clear and easy to start with.
Ankur
bjornarsb Tue, 05/08/2007 - 08:40
  • Bronze, 100 points or more
I suppose that you have configured trunk between your 2950 and 4006 ?
The mgmt vlan must be the same on both sides and it need to be allowed on the trunk (if you have a filter)
A quess is that you have link, but problems with trunk negotiation.
Bjornarsb
Amit Singh Wed, 05/09/2007 - 02:52
  • Cisco Employee,
Paul,
Please paste your switch configurations from both the sides.
-amit singh
