Receiving Incomplete faxes
May 8th, 2007
An ATA186 that is registered with the CCM is being used to support a modem that will allow a PC attached to it to receive faxes. When receiving multipage faxes only the first page arrives. Do you have any idea of what might be the reason for this malfunction?
anabartolomeu Fri, 05/11/2007 - 08:49
I'm using FAX relay.
Anyway the problem is already solved. It was due to slip errors on the E1 controllers.
