05-08-2007 08:49 AM - edited 03-14-2019 09:22 PM
Have a 0.X route pattern using OverlapSending. Everything works OK for PSTN calls.
But when trying to CFwdALL to a PSTN destination is impossible, the diverted number is accepted straight away after 2nd digits.
Solved! Go to Solution.
05-08-2007 09:01 AM
to overcome this, you need to configure an additional route pattern with a wildcard character, such as "0.!" and put this in a separate partition. Create a additional CSS and assign this on the line CallForward-CSS.
regards
mehmet
05-08-2007 09:01 AM
regards
mehmet
