Switching
Get 20% off switches when you combine Cisco solutions
Labels
My company has 4 Call Manager subscribers, two at our HQ datacenter and two at our colocation.   We powered down everything at our colo this part Saturday because we are moving it out of state.  Since then, we have had random locations having switch ...
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 321 Views
  • 13 replies
Acabei de criar uma vlan, atribuí-la a uma porta em nosso 6509, atribuí à vlan um endereço IP e quando eu disparo o comando, show int vlan 31 ele diz que a vlan está administrativamente inativa. Não consigo descobrir o que está acontecendo aqui? emit...
ftoprakw by Level 1
  • 56 Views
  • 0 replies
Hi, I am working on a RFP where one of the specs says " the switch should support IEEE802.3ah ethernet link OAM and IEEE 802.1ag/ITU-T Y.1731" this is the only point which i am not able to find a reference in cisco documents, though we have a cisco 9...
Hey guys,I would like to know about downloading crashinfo file from the flash drive.Pls see below:RSW01#dirDirectory of flash:/ 2 -rwx 5708466 Feb 28 1993 19:57:48 -06:00 c2960-lanbasek9-mz.122-35.SE.bin 3 -rwx 1048 May 16 2008 ...
CIAOUn cliente ci chiede quanto calore produce un interruttore 3650 per calcolare l'HVAC per il raffreddamento. Stiamo controllando la SCHEDA DATI ma le uniche informazioni a riguardo sono il flusso d'aria e la temperatura operativa.Qualcuno sa dove ...
umutsare by Level 1
  • 37 Views
  • 0 replies
Hi, I have a C2960L-SM and noticed that I can't connect over ssh anymore. I getssh_exchange_identification: Connection closed by remote host If I run show ip ssh it seems ssh is running:SSH Enabled - version 1.99 ... and so on What can I do? Especial...
tokon by Level 1
  • 7436 Views
  • 23 replies
Resolved! vmware nic teaming
Hi, if NIC are teamed on VMWARE  and set to "route based on the orginating virtual id" do i need to port-channel on the cisco switch ?
