Time Stamps wrong in log.
Answered Question
May 8th, 2007
I'm having an issue with a few of the routers on my network. The output of the show clock command displays the correct time, but the log entries are off by about 5-ish hours. Is the router sitting in a time-warp? Events are happening in the future(?) :P
Ex:
May 8 17:39:05.144: %ENTITY_ALARM-6-INFO: ASSERT MINOR AT1/0 Physical Port Link Down
<hostname>#sh clock
12:45:51.975 cdt Tue May 8 2007
Config is as such:
clock timezone cst -6
clock summer-time cdt recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ntp clock-period 17179830
ntp update-calendar
ntp server <IP of NTP Server> prefer
The router that I copied the above example from is a 7206 running:
Version 12.4(7b)
I also see this problem with some other 7206s as well as a few 1841s. Doesn't seem to be any correlation. Ideas why this is??
Correct Answer by Joe Clarke about 9 years 11 months ago
The log messages are showing a UTC time stamp. Please include the service portion of the config as well. You probably want to add:
service timestamps log datetime localtime
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Tue, 05/08/2007 - 09:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
att0055rj Tue, 05/08/2007 - 10:06
As requested:
Joe Clarke Tue, 05/08/2007 - 10:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yep, just add a localtime in there, and you'll get localized time stamps. You might also want to add show-timezone to see to what timezone they're localized. And because I'm pedantic, timezones are usually written in all upper case (i.e. CST and CDT).
