SUP720 IOS
Amit Singh Tue, 05/08/2007 - 21:54
  • Cisco Employee,
Chris, If you are upgrading a module in the modular IOS that means you are effectively doing a software upgrade of a failed module/process.This is a littile different as you have to only upgrade the effected module patch rather than the whole IOS on the Sup engines.
HTH,Please rate if it does
-amit singh
