MPE-LE 2.0
Answered Question
May 8th, 2007
Does anyone know if Meeting place express provides redundancy or load balancing. I will be proposing Cisco MPE with (2) MCS 7845 Servers for redundancy, but couldn't confirm if MPE application can support redundancy or load balancing.
Correct Answer by thisisshanky about 9 years 10 months ago
I have not heard of an active standy solution, but for security reasons if you want to have one MPE server to handle internal web meetings and another one to handle external web meetings, you can keep this separate using MPE2.0. You will buy a second server and an add on MPE software bundle that will enable only web conferencing on the second server. When users schedule a meeting, they can choose if this meeting needs to be published only with in the company or to the 2nd server (Internet). This feature is called SMA - Segmented Meeting Access.
If you get a second 7845, you get the capability to run 200 web sessions.
Overall Rating: 5 (1 ratings)
Correct Answer
thisisshanky Tue, 05/08/2007 - 15:21
  • Purple, 4500 points or more
thisisshanky Tue, 05/08/2007 - 15:22
Sankar
PS: please remember to rate posts!
Sankar
