IP Communicator / Juniper SSL/VPN
May 8th, 2007
For a CME project, client has a Juniper SSL/VPN running Java Secure Access Manager(JSAM). Client wants staff to use IP Communicator but cannot verify or document interoperability of IPComm w/ JSAM SSL/VPN. Any info is greatly appreciated
Tommer Catlin Tue, 05/08/2007 - 13:56
Here is some good information for you. If your SSL vpn is configured correctly, and your client on the remote can "talk" to the CME server, you should be fine.
http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_administration_guide_chapter09186a008020ad96.html
The Audio ports need to be open or defined back and forth as well as TFTP to and from CME. HTTP will also be needed for Services, etc.
HOpe this helps!
Chris Deren Tue, 05/08/2007 - 14:26
COuple of my customer use Juniper SSL vpn and I have no issues with IP Communicator with CallManager (should be no different with CME).
Chris
