Max number of conferences that ip phones support
May 8th, 2007
I need the maximum number of conferences that an IP phone supports. I need this information for all IP Phones, especially 7911,7941,7961,7970,7971,7985.. I couldn't find the info in data sheets..
Overall Rating: 5 (1 ratings)
Chris Deren Tue, 05/08/2007 - 14:30
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Not sure if I understand your question?
You can have one conference per line if that answers it as the phone does not mix the conference sessions, rather the conference (software, hardware) does.
Chris
ozgurguler Tue, 05/08/2007 - 14:39
You are right, question was wrong.. With an ip phone.for example 7911, how many conference participants can i talk to? (in one conference session). I need this info for all models.
ozgurguler Tue, 05/08/2007 - 14:45
Isn't there any limitation for ip phones. Can i talk simultaneously a lot of people, if i have enough capacity conference bridge then?
Chris Deren Tue, 05/08/2007 - 14:57
  • Hall of Fame,
Correct, you can have one active call on the phone at a time (others will be on held), so all the phone does is connect to one destination - conference brdige, which mixes the streams.
Whatever you use as the conference bridge source will allow you to stream different number of conferencees.
Chris
