Cor List with nip autentifications
robert.bernal
Hello Guys, Im setting up CCME but i want to use a dial-peer with:
destination-pattern 9T
I need to block Cell calls, with an Nip
How can i do this with out Cor List.
Regards.
9 Replies 9
paolo bevilacqua
You mean a PIN ?
This is after-hours / login configuration.
See:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a008080d9ad.html#wp1011535
thanks for your reply
I was looking the way to authentificate users
before the may the col and i found in this forum a Cor list integration with AAA autentification, and its done.
May be you saw tcl ivr aaa authentication ?
What are you referring to ?
The script acctfixedpin.tcl is an unsupported script (originally written by John Rosinski) which provided
authentication of users via accounts on a Radius server. I modified this a little using COR on CCME to
provide local authentication without a RADIUS server. See configurations below which I am using in a
production environment in Mexico.
! Put acctfixedpin.tcl file on router flash
! Put enter_account.au on flash
! These are some sample 5-digit PIN codes entered on the router for local authentication
security passwords min-length 6
username 12345 password 0 123456
username 54321 password 0 123456
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
Very good, may I ask you to post the script ?
I did the same for modifications to AA-BACD and a recorder script.
Here is the Script, i make few changes, i attach my confs too.
Its working good.
Regards.
Great, thanks!
hy,
i have the same thing, but it doesn't work for me, i have CCME.
i have applied the script and when i dial the number, the message "connected" is displayed in the screen and the call is terminated after few seconds.
Please help me to solve this problem.
thanks.
I got lucky, working fine with CME 8.5. Great share, thanks a lot
Rgds,
Tonka
