Logging VPN connections
May 8th, 2007
Greetings All,
I have a customer who wishes to log all VPN user activity on their ASA5510 so he can look back and see who was using a VPN connection on a particular day.
I can see in the ASDM how you can see real time, who is on but do you know what logging command I need to use to log this activity for reference so that it can be viewed at a later date?
Overall Rating: 4 (1 ratings)
haroon.shaikh Wed, 05/09/2007 - 12:37
Thanks Jay,
But my issue is that VPN users are already authenticated locally. My only requirement is that I want ASA to send syslogs of the connections made by VPN clients.
i.e. Everytime a VPN client logs in, ASA should send a syslog to syslog server.
laurent.geyer Wed, 05/09/2007 - 12:54
My firewall logs this as %ASA-7-713052.
May 3 09:31:37 xxxfrwxxx %ASA-7-713052: Group = xxx, Username = xxx, IP = aaa.bbb.ccc.ddd, User (xxx) authenticated.
This is just one of many log messages that I see upon authentication.
laurent.geyer Wed, 05/09/2007 - 13:17
Logging is configured pretty verbose.
logging enable
logging timestamp
logging standby
logging console debugging
logging monitor debugging
logging buffered debugging
logging trap debugging
logging history debugging
logging asdm debugging
logging facility 21
logging host inside aaa.bbb.ccc.ddd
logging host inside aaa.bbb.ccc.eee
no logging message 710005
no logging message 710003
Here's the failure message btw.
May 3 17:46:02 xxxfrwxxx %ASA-3-713167: Group = xxx, Username = xxx, IP = aaa.bbb.ccc.ddd, Remote peer has failed user authentication - check configured username and password
