Rate Limiting on ISP router
We have multiple internal lans/networks sharing a common internet pipe/link terminated on a Cisco router.
We have seperate NAT IPs ( Public IPs ) configured for each network to differentiate them from one another outside the firewall.
My requirement is like this ,
1) I want to do a QOS on my internet router by restricting a maximum of 1 Mb internet bandwidth for each internal network.
2) Presently i have configured a rate-limiting command on my interface with a matching ACL.
interface FastEthernet0/1
description ### MY ISP facing interface ###
ip address xxx.xxx.xxx.xxx 255.255.255.252
rate-limit input access-group 101 1024000 64000 64000 conform-action transmit exceed-action drop
rate-limit output access-group 102 1024000 64000 64000 conform-action transmit exceed-action drop
access-list 101 remark ### input ACL 4 BW Cap test for network1 ###
access-list 101 permit ip any host network1-NAT-IP
access-list 101 remark ### deny any any ###
access-list 101 deny ip any any
access-list 102 remark ### output ACL 4 BW Cap test for network1 ###
access-list 102 permit ip host network1-NAT-IP any
access-list 102 remark ### deny any any ###
access-list 102 deny ip any any
3) What will happen if i add one more NAT-IP in my rate-limit matching ACL as shown below.
access-list 101 remark ### input ACL 4 BW Cap test for network2 ###
access-list 101 permit ip any host network2-NAT-IP
access-list 102 permit ip host network2-NAT-IP any
!! a) Will my second network ( network2-NAT-IP) will also have a maximum BW cap of 1 Mb
!! b) Is so can I add all more QOS needed NAT IPs to this matching ACL.
Any help regarding the same is appreciated
Overall Rating: 3.5 (2 ratings)
hoogen_82 Tue, 05/08/2007 - 22:23
a) Your second network would also have the same set of parameters.
b) You can more networks.
-Hoogen
Do rate this post if it helps :)
