Static NAT assignments + Pooling?
Answered Question
May 8th, 2007
So, up front, I have relatively little experience configuring NAT. I have no problem getting a pool working, but I have no idea how to add a static NAT for something like a server into the mix. As follows is the relevant portion of my config as I currently have it (it seems to be working as expected):
ip nat pool **** 75.62.*.130 75.62.*.254 netmask 255.255.255.128
ip nat inside source list 10 pool **** overload
ip nat inside source static 10.0.0.54 75.62.*.204
ip nat inside source static 10.5.0.49 75.62.*.205
access-list 10 permit 10.0.0.0 0.255.255.255
* indicates scrubbed info
I can access the .204 address from outside and have connectivity from inside...I'm wondering if the fact that I have assigned these two static addresses inside the pool's range will cause issues. Please get back to me ASAP...has to go live as soon as I know hehe. Thanks a ton.
Ankur has absolutely right.
Found the following on the NAT FAQ.
"Q. Is it possible to build a configuration with both static and dynamic NAT translations?
A. Yes, this is possible. The caveat that the global addresses use in static translations are not automatically excluded with dynamic pools that contain those global addresses. You must create your dynamic pools to exclude addresses assigned via static entries."
So your pool should exclude the global address you want to use for static mapping.
Kriszti?n
Correct Answer by ankbhasi about 10 years 2 months ago
Hi Friend,
AFAIK you must create your dynamic pools to exclude addresses assigned via static entries it is because the caveat that the global addresses use in static translations are not automatically excluded with dynamic pools that contain those global addresses.
Ankur
*Pls rate all helpfull post
Overall Rating: 5 (2 ratings)
Correct Answer
ankbhasi Tue, 05/08/2007 - 23:53
  • Cisco Employee,
Hi Friend,
Ankur
Correct Answer
Kriszti?n
