Can outdoor AP really can be used without protection in external area?
May 8th, 2007
Hi All,
Can AP for outdoor can be used for outdoor without any protection? for my previous project, I use a weather proofed box to protect the AP, drill a hole in the weather proofed box to connect external antenna to the outdoor AP inside. But I am doubting if that is necessary. If outdoor AP is already ok for external area, I will just use without protection in my next project. I am not sure if I can do that, although many outdoor AP say that they are "weather proof" in their datasheet. Is there anybody who has experience to give me a hint??
Thank you!
Best Regards,
Teru Lei
sethgarnar Wed, 05/09/2007 - 06:22
We have 6 1300 series outdoor units that are located on top of buildings with no protection. They have been in service for almost three years now and have never had to service them. We're located in upstate NY so we get a wide range of weather.
teru-lei Wed, 05/09/2007 - 18:09
Thanks! do you have lightning arrester, grounding or use fiber etc to prevent effect of lightning?
scottmac Thu, 05/10/2007 - 05:33
You should use both.
The so-called "lightning arrester" won't do much for you in the event of a lightning strike (or near-hit), but they do serve to drain atmospheric static (caused by wind / dust / snow) that can build up and damage the equipment behind the AP.
A segment of fiber will block the lightning, but static buildups are a surface effect ... it's possible that they could be carried across the fiber link (not real likely, but possible).
Also, as pointed out by another poster in a similar post/response a couple weeks ago, you should probably use isolated / segregated power to feed the devices at each end of the fiber (transceivers or switches) to prevent the lightning from bypassing the fiber segment through the power lines.
It's always a good thing to review your local electrical codes, as well as any state and / or federal codes ... the local regulations are generally targeted to protect the user/consumers from likely local "events."
It might also be worthwhile to talk to radio (installation) professionals in your area and get their recommendations. It might cost a few bucks up-front, but it's usually worth it to keep the lightning (and atmospheric charges) outside where they belong.
Good Luck
philliploveless Mon, 05/14/2007 - 08:40
Yes, I deployed a 1300 series access point outside and have been running it in production for 6 months thru adverse weather conditions with no issues.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
