Opening ports to be used on 4506 ...
May 9th, 2007
I have a camera system that needs to use ports 5001 and 5002 on a 4506 system ... How do I make these ports available to the camera system ?
Surprisingly it works with no issues on the 2950 switch.
[1] Doees anyone know how do I make this port available 5001 and 5002 for the camera on the 4506s (inbound/outbound UDP ?
Thank you,
- Sanjay -
Amit Singh Wed, 05/09/2007 - 00:10
  • Cisco Employee,
Snajay,
You cannot open the ports as such on the 4506. let us know the topology/configuration done on 4506.
How was the config done on 2950. Were these used in the same vlan on 2950.
How is the cameras configured on 4506. Are they in the same vlan or different vlan.
-amit singh
glen.grant Wed, 05/09/2007 - 03:41
  • Purple, 4500 points or more
By default all ports are allowed unless someone has put an acl or other restrictions on the port , sounds like a misconfiguration of the switch .
