NMS and Ciscoworks discovery
May 9th, 2007
Hi folks,
can you advise, I know that Campus mnager does device discovery but can it import discovery from a 3rd party NMS ie HP NNM instead otherwise you'll end up with both NMS and CWKS doing the same thing?
Overall Rating: 5 (1 ratings)
jreekers Wed, 05/09/2007 - 06:27
Hi Tony.
You can absolutely import devices from HPOV NNM into the DCR (Device Credential Repository) of LMS. You can do it either by selecting the 'bulk import' button (under Common Services >Device Credentials > Device Management) to import devices from HP Openview, or you can do it through the dcrcli on the LMS server.
Also, there isn't a lot of overlap between NNM and Ciscoworks. Many customers use both in the same network as they complement each-other in capabilities.
Finally, for LMS issues, you might want to post on the Network Management forum under "Network Infrastructure" here in the left-hand column.
Thanks, and HTH,
