LMS 2.5 upgrade to 2.6
May 9th, 2007
Hi folks,
whats the cost for this upgrade, any ideas?
Cheers
Tony
Overall Rating: 5 (1 ratings)
Martin Ermel Wed, 05/09/2007 - 03:01
if you have LMS 2.5 the upgrade to LMS 2.6 is free of charge;
You just need to install the necessary patches, i.e you need to install the upgrade from LMS 2.5 to 2.5.1 available here:
http://www.cisco.com/cgi-bin/tablebuild.pl/lms25
and then you can go to LMS 2.6:
http://www.cisco.com/cgi-bin/tablebuild.pl/lms26
Additional application patches are availabe for LMS at
http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml
Consider to whipe out the databases (reinitialze) and start a fresh discovery afterwards (it depends on the size of your network and the way how devices are propagate into the apps [CM, RME, DFM]). In my opinion, sometimes its quicker then to deale with problems from the previous versions of LMS...
pcuervo123 Fri, 05/11/2007 - 06:12
I think only in case you have a Ciscoworks software service contract. Otherwise it's not free.
