CW and NMS integration
May 9th, 2007
Hi folks,
can you advise, I know that Campus mnager does device discovery but can it import discovery from a 3rd party NMS ie HP NNM instead otherwise you'll end up with both NMS and CWKS doing the same thing?
Cheers
Tony
Joe Clarke Wed, 05/09/2007 - 07:17
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Campus Manager doesn't actually do the importing, but Common Services can import from HPOV NNM as well as Tivoli NetView. So, yes, you can centralize your discovery with NNM, then import those devices into the Device Credential Repository for use by all LMS applications.
