05-09-2007 01:32 AM - edited 03-15-2019 04:50 AM
Hi Everyone,
I am trying to export the personal speed dials added by a user to the IPMA Assistant Console. Looked everywhere (well almost) but can't find out where this info is stored.
I have looked in the SQL database tables (but not all 600+ of them) just the device, speeddials, numplan, users, etc to name but a few.
I have also looked in the LDAP/DC directory and not found out where it is? All I could find here is a few entries of the Fastdials. I looked here because it says in the doc.s that IPMA uses LDAP.
Please help if you have any ideas or suggestions as to where to look as I have run out of ideas.
Thanks and regards
Raj
05-15-2007 05:35 AM
The Speed Dials are stored under DC Directory CCN->user_info->assistant_info->MA node in a binary blob (Serivce/Device) format for an individual assistant. IPMA don't have mechanism to copy over these speed dial details to another assistant.
the only possibility to use BARS and do a CCM backup.
06-20-2007 08:23 AM
Hi there,
I currently doing a migration from CM4.0 to CM5.1.
I have around 50 users using the IPMA Assistant Console. I need to port over all their Speeddials in the console.
Anyone done this before? Appreciate any reply... :)
