877W unable to view web pages
May 9th, 2007
Hi all,
I've been trying to setup the new 877W DSL router for last days with no luck.
Situation is as follows:
Everything seems to be alright, DSL connects properly, and my pc is able to ping and traceroute to sites.
Problem comes when trying to use the web browser, I'm not getting any kind of heavy page (it does load google after 30 secs).
I've checked it does NAT translations as I can see them with the sh ip nat translations command.
I'm copying the whole config. Thanks in advance for your help, Any comment will be helpful.
mohammedmahmoud Wed, 05/09/2007 - 03:29
  • Green, 3000 points or more
2 things to try, first you say that you can ping sites while not able to web browse, it might be a DNS problem accordingly please try to check your dns (ping the DNS and then try doing nslookup).
Second, for the MTU and MSS its recommended to have:
interface
ip tcp adjust-mss 1452
interface
mtu 1492
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
