Help, I can?t apply WLAN through WCS
May 9th, 2007
Hello folks
I?m using WLC 4402 (v.4.0.206.0) with WCS 4.0.81.0
When I create a new WLAN template in WCS and try and apply it to my controller I get this error reason: "SNMP operation to Device failed: Set for this object is not supported anymore"
Why is this happening ?
dbentley Tue, 05/15/2007 - 06:24
Good find. Thank you for sharing the thread. The WCS should be close to the same software version as your controller to get the best operability.
