Export or Convert CAR 4.0 Database
May 9th, 2007
Hi All,
We currently have CAR 4.0 implemented with local database. Since the number of users is constantly growing, we were wondering if there is any ?easy? way to migrate into an SQL database solution (Oracle or MySQL)
a) Is there any other tool for converting it into SQL (Oracle)?
b) Is there any tool for exporting the CAR 4.0 local database into an XML or Comma delimited format?
Regards.
Overall Rating: 3 (1 ratings)
pavlosd Tue, 05/15/2007 - 08:30
What you are descriping is for Call manager.... What about Cisco Access Registrar 4.0?
The local database has 3 files....
/cisco-ar/data/db/
mcddb.d01, mcddb.d02, mcddb.d03
David Stanford Tue, 05/15/2007 - 09:38
  • Cisco Employee,
Not sure if this helps:
/cisco-ar/usrbin/mcdadmin: [-c] -d {dbdirname|DEFAULT} -[r|R] DBPATH -p
DBPATH -i importfile -e exportfile [-z C=N]
where:
-c attempts to create database
-o when creating, overwrite pre-existing database
-T recopy database templates when creating database
-t DIR specifies directory from which to get database templates
-d DBNAME specifies the database name, or "DEFAULT"
-N NAME specifies username (will prompt if not given)
-P PASSWORD specifies password (will prompt if not given)
-s supplies default name and password
-i IMPORTFILE specifies file to import from. ("-" for stdin)
-l don't hold exclusive lock while importing (slower, but
friendly)
-e EXPORTFILE specifies file to export to. ("-" for stdout)
-f EXPORTFILE exports diffable file (not importable) to export
-a DBAREA specifies the "area" of the database to use
("config", "state", "altconfig", or "altstate",
defaults to "config"
-p DBPATH specifies (on export only) what to export
-r DBPATH specifies something to remove ("trims" table)
-R DBPATH removes recursively! (or "clobbers" table)
The use of DBPATH in -p, -r, and -R is as follows: either
it is an absolute pathname, starting with '/', in which
case it refers to that part of the MCD tree, or it is a
"server zone name" tuple, starting with ':'. The names
after
the ':' are whitespace separated, and the name or zone and
name may be left unspecified. example: -p "myserv azone
foo"
-G GENERATION specifies generation number for RR table export
-H says full table generational history should be dumped
-k kill the lockmgr, do nothing else
-z CCC=N sets debugging classes CCC to level N
-v, -V prints version information
pavlosd Sun, 05/20/2007 - 06:28
OK, seems helpful enough.....
Do you have any syntax example? I do not want to mess up with my existing database .... :-(
