May 9th, 2007
good day, I have a problem catalyst 3560 since he himself after several days, it sends a message to me of which it has low memory, does not allow me to access VTY way and no Console way, after some hour does not respond echo to me ICMP and by ultimi it lets comutar and the communication is affected,
this problem is due to I deal corupt in my network? or it is a problem of makes of these equipment?
avmabe Wed, 05/09/2007 - 05:48
  • Bronze, 100 points or more
I would recommend you plug into the console of the 3560 and if it is not responding, reboot and watch the console as it boots and try to login immediately when it comes up.
Also, if you are getting messages of "low memory" I assume snmp traps or syslog is setup. Are there any other messages?
