VPN L2L
I'm having trouble setting up a pix to pix vpn connection...I'm running a pix 515 v 7.0 on one end and a pix 515e 6.3 on the other end, here's the vpn configs (I starred out the public IPs) The tunnel I'm working on is the vpntunnel 21 and europe:
europe:
access-list 101 extended permit ip 192.168.71.0 255.255.255.0 192.168.70.0 255.255.255.0
access-list 101 extended permit ip 10.20.1.0 255.255.255.0 192.168.70.0 255.255.255.0
nat-control
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0
crypto ipsec transform-set RTS esp-3des esp-sha-hmac
crypto ipsec transform-set london esp-3des esp-md5-hmac
crypto map RTS 1 set peer *******
crypto map RTS 1 set transform-set RTS
crypto map vpntunnel 21 match address 101
crypto map vpntunnel 21 set peer ******
crypto map vpntunnel 21 set transform-set london
crypto map vpntunnel interface outside
isakmp identity address
isakmp enable outside
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 10000
tunnel-group RTS type ipsec-l2l
tunnel-group ****** type ipsec-l2l
tunnel-group ****** ipsec-attributes
pre-shared-key *
pre-shared-key *
London:
access-list 101 permit ip 192.168.70.0 255.255.255.0 192.168.55.0 255.255.255.0
access-list 101 permit ip 172.16.70.0 255.255.255.0 172.17.5.0 255.255.255.0
access-list 101 permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
access-list 101 permit ip 192.168.70.0 255.255.255.0 10.20.1.0 255.255.255.0
access-list hk permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
access-list hk permit icmp 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
access-list hk permit ip 192.168.70.0 255.255.255.0 10.20.1.0 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
sysopt connection permit-ipsec
crypto ipsec transform-set ny esp-des esp-md5-hmac
crypto ipsec transform-set europe esp-3des esp-md5-hmac
crypto map vpntunnel 1 ipsec-isakmp
crypto map vpntunnel 1 match address 102
crypto map vpntunnel 1 set peer ******
crypto map vpntunnel 1 set transform-set ny
crypto map europe 5 ipsec-isakmp
crypto map europe 5 match address hk
crypto map europe 5 set peer ******
crypto map europe 5 set transform-set london
crypto map europe interface outside
isakmp key ******** address ****** netmask 255.255.255.255
isakmp policy 6 authentication pre-share
isakmp policy 6 encryption 3des
isakmp policy 6 hash md5
isakmp policy 6 group 2
isakmp policy 6 lifetime 86400
The tunnel seems to come up normal when I initiate it from the london side, but not from the europe side. Also even though the tunnel is up, no traffic seems to be going through, I'm not able to connect to any devices on the other side:
Europe:
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: *******
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
London:
Total : 1
Embryonic : 0
dst src state pending created
****** 172.16.70.100 QM_IDLE 0 1
any ideas what I'm doing wrong here??
acomiskey Wed, 05/09/2007 - 05:42
I would start by getting rid of
as it is not needed and the acl's should be mirrors of eachother on the two fw's.
acomiskey Wed, 05/09/2007 - 05:52
Try making 2 separate acl's for your europe fw, one for nat exemption and one for crypto, don't use 101 for both.
Yup tried that also...only reason I tried the same one for both was because it wasn't working. Anyway I just switched it back to seperate ACls, still same problem:
access-list london-nat extended permit ip 192.168.71.0 255.255.255.0 192.168.70.0 255.255.255.0
access-list london-nat extended permit ip 10.24.1.0 255.255.255.0 192.168.70.0 255.255.255.0
nat (inside) 0 access-list london-nat
yea typo :) Been working on this too many hours:) Fixed it but still same problem...I'm getting these messages in syslog when trying to connect though:
when initiated from europe:
10.20.1.254,May 08 2007 14:05:57: %PIX-6-609001: Built local-host inside:10.20.1.250
10.20.1.254,May 08 2007 14:05:57: %PIX-6-305011: Built dynamic TCP translation from inside:10.20.1.250/50498 to outside:172.16.71.100/1381
10.20.1.254,May 08 2007 14:05:57: %PIX-6-302013: Built outbound TCP connection 591 for outside:192.168.70.253/23 (192.168.70.253/23) to inside:10.20.1.250/50498 (172.16.71.100/1381)
when intiated from london:
192.168.70.100,%PIX-6-302013: Built outbound TCP connection 19183 for outside:10.20.1.250/23 (10.20.1.250/23) to inside:192.168.70.253/63170 (192.168.70.253/63170)
10.20.1.254,May 08 2007 14:06:27: %PIX-6-302014: Teardown TCP connection 591 for outside:192.168.70.253/23 to inside:10.20.1.250/50498 duration 0:00:30 bytes 0 SYN Timeout
10.20.1.254,May 08 2007 14:06:57: %PIX-6-305012: Teardown dynamic TCP translation from inside:10.20.1.250/50498 to outside:172.16.71.100/1381 duration 0:01:00
10.20.1.254,May 08 2007 14:06:57: %PIX-6-609002: Teardown local-host inside:10.20.1.250 duration 0:01:00
Doesn't look like the traffic is actually crossing the tunnel.
acomiskey Wed, 05/09/2007 - 06:42
What is 172.16.71.100, pat address? It seems like nat exemption is not working at europe fw.
that's the DMZ side of the FW in europe...I just tried from another host that definetly doesn't attempt any dmz connections to see if I see any translations created:
europeSW-01's IP is 192.168.71.200
europeSW-01#telnet 192.168.70.200
Trying 192.168.70.200 ...
% Connection timed out; remote host not responding
EUROPE-FW-01# sh log | i 70.200
May 08 2007 14:46:21: %PIX-6-609001: Built local-host outside:192.168.70.200
May 08 2007 14:46:21: %PIX-6-609002: Teardown local-host outside:192.168.70.200
duration 0:00:00
May 08 2007 14:46:25: %PIX-6-609001: Built local-host outside:192.168.70.200
May 08 2007 14:46:25: %PIX-6-609002: Teardown local-host outside:192.168.70.200
duration 0:00:00
EUROPE-FW-01# sh log | i 71.200
May 08 2007 14:46:33: %PIX-6-609001: Built local-host inside:192.168.71.200
May 08 2007 14:46:33: %PIX-6-609002: Teardown local-host inside:192.168.71.200 d
uration 0:00:00
EUROPE-FW-01# sh xlate | i 71.200
EUROPE-FW-01#
acomiskey Wed, 05/09/2007 - 06:59
Doesn't this mean that 10.20.1.250 is being translated to 172.16.71.100?
Yea that was before I corrected the 10.24 acl...here's the new syslogs:
2007-05-09 11:10:36,Local4.Info,10.20.1.254,May 08 2007 15:10:57: %PIX-6-609001: Built local-host inside:10.20.1.250
2007-05-09 11:10:36,Local4.Info,10.20.1.254,May 08 2007 15:10:57: %PIX-6-609002: Teardown local-host inside:10.20.1.250 duration 0:00:00
2007-05-09 11:10:38,Local4.Info,10.20.1.254,May 08 2007 15:10:59: %PIX-6-609001: Built local-host inside:10.20.1.250
2007-05-09 11:10:38,Local4.Info,10.20.1.254,May 08 2007 15:10:59: %PIX-6-302020: Built ICMP connection for faddr 192.168.70.253/0 gaddr 10.20.1.250/28 laddr 10.20.1.250/28
2007-05-09 11:10:46,Local4.Info,10.20.1.254,May 08 2007 15:11:07: %PIX-6-302021: Teardown ICMP connection for faddr 192.168.70.253/0 gaddr 10.20.1.250/28 laddr 10.20.1.250/28
2007-05-09 11:10:46,Local4.Info,10.20.1.254,May 08 2007 15:11:07: %PIX-6-609002: Teardown local-host inside:10.20.1.250 duration 0:00:08
2007-05-09 11:10:52,Local4.Info,10.20.1.254,May 08 2007 15:11:12: %PIX-6-609001: Built local-host inside:10.20.1.250
2007-05-09 11:10:52,Local4.Info,10.20.1.254,May 08 2007 15:11:12: %PIX-6-302013: Built outbound TCP connection 1202 for outside:192.168.70.253/23 (192.168.70.253/23) to inside:10.20.1.250/46402 (10.20.1.250/46402)
007-05-09 11:11:22,Local4.Info,10.20.1.254,May 08 2007 15:11:42: %PIX-6-302014: Teardown TCP connection 1202 for outside:192.168.70.253/23 to inside:10.20.1.250/46402 duration 0:00:30 bytes 0 SYN Timeout
2007-05-09 11:11:22,Local4.Info,10.20.1.254,May 08 2007 15:11:42: %PIX-6-609002: Teardown local-host inside:10.20.1.250 duration 0:00:30
2007-05-09 11:12:28,Local4.Info,10.20.1.254,May 08 2007 15:12:49: %PIX-6-609001: Built local-host inside:10.20.1.250
2007-05-09 11:12:28,Local4.Info,10.20.1.254,May 08 2007 15:12:49: %PIX-6-302013: Built outbound TCP connection 1223 for outside:192.168.70.253/23 (192.168.70.253/23) to inside:10.20.1.250/28994 (10.20.1.250/28994)
2007-05-09 11:12:58,Local4.Info,10.20.1.254,May 08 2007 15:13:19: %PIX-6-302014: Teardown TCP connection 1223 for outside:192.168.70.253/23 to inside:10.20.1.250/28994 duration 0:00:30 bytes 0 SYN Timeout
2007-05-09 11:12:58,Local4.Info,10.20.1.254,May 08 2007 15:13:19: %PIX-6-609002: Teardown local-host inside:10.20.1.250 duration 0:00:30
I'm starting to think the problem is on the dmz router...here's the setup:
londonfw-dmzrouter-internet-europterouter-eurotefw
I'm getting these messages on the london router (the source and dest addresses are correct):
ip nat inside source static tcp 172.16.70.100 500 ***** 500 extendable
.May 9 15:35:11.019: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet ha
s invalid spi for
destaddr=*****, prot=50, spi=0x35B97736(901347126), srcaddr=*****
I just found this config left out by the previous engineer on the london router...I'm guessing this is conflicting. I'll try to remove the crypto map later on tonight and see if it works:
interface FastEthernet0
ip address ****** 255.255.255.248
ip access-group 130 in
ip nat outside
ip route-cache flow
speed auto
Ok I got a new problem...now the tunnel gets created fine no matter where I initiate traffic from...however, if I initiate the traffic from london, after the tunnel gets created no traffic is able to pass through the tunnel. As soon as I send any kind of traffic out from europe everything works fine both ways. Any ideas why that would happen?
Ok this is starting to drive me crazy I think. It looks like I have to initiate interesting traffic from both ends before the connection actually works. On the London router (not the FW) I'm getting these messages:
May 10 17:16:42.170: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has
invalid spi for
destaddr=*.*.*.*, prot=50, spi=0x354F6836(894396470), srcaddr=*.*.*.*
I'm using a static nat on that router for the fw (the public IP is the same as the outside interface):
ip nat inside source static tcp 172.16.70.100 500 217.196.246.234 500 extendable
hoogen_82 Thu, 05/10/2007 - 10:10
OKay i will try to rebuild your configuration also for your case do try to clear crypto ipsec sa and clear crypto isakmp sa and try setting up the tunnel and see if traffic is flowing through.
hostname europe
enable password 2KFQnbNIdI.2KYOU encrypted
names
access-list 100 extended permit ip any any
access-list nonat extended permit ip 192.168.71.0 255.255.255.0 192.168.70.0 255.255.255.0
access-list nonat extended permit ip 10.20.1.0 255.255.255.0 192.168.70.0 255.255.255.0
icmp permit any outside
icmp permit any inside
nat-control
global (outside) 1 interface
nat (inside) 0 access-list nonat
access-group 100 in interface inside
route outside 0.0.0.0 0.0.0.0 xx.x.x.x 1(Make sure your routing is good)
crypto ipsec transform-set RTS esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec df-bit clear-df outside
crypto map forsberg 21 match address nonat
crypto map forsberg 21 set peer
crypto map forsberg 21 set transform-set RTS
crypto map forsberg interface outside
isakmp policy 1 hash sha
isakmp policy 1 lifetime 86400
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
hostname europe
names
access-list nonat extended permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
access-list nonat extended permit 192.168.70.0 255.255.255.0 10.20.1.0 255.255.255.0
nat-control
pre-shared-key *
One thing to notice the extra intresting traffic from London to europe PIX, if you notice in Europe you dont have it marked as interesting.
Hoogen
hoogen_82 Thu, 05/10/2007 - 10:13
Oops lots of changes before i could post mine. Well do you have a diagram and what are you trying to achieve..
-Hoogen
hoogen_82 Thu, 05/10/2007 - 11:16
Okay this should be your config
hostname europe
enable password xxx
names
nat-control
crypto map forsberg 21 set peer 172.16.70.100
tunnel-group 172.16.70.100 type ipsec-l2l
tunnel-group 172.16.70.100 ipsec-attributes
pre-shared-key *
hostname europe
enable password xxx
names
nat-control
route outside 0.0.0.0 0.0.0.0 172.16.71.253
crypto map forsberg 21 set peer 172.16.71.100
tunnel-group 172.16.71.100 type ipsec-l2l
tunnel-group 172.16.71.100 ipsec-attributes
pre-shared-key *
THe above config should work good. Just confused about the Ip'S on your routers though, let your routers only do routing, leave the firewall portforwarding tunnel stuff to the pix.
Hoogen
Yea the tunnel is created on the pix...the only relevent lines in the routers are:
London:
ip nat inside source static tcp 172.16.70.100 500 *.*.*.* 500 extendable
Europe:
ip nat inside source static udp 172.16.71.100 500 *.*.*.* 500 extendable
Because the target public IP for the tunnel is the same as the public IP of the outside (which it's overloading).
I'll compare my configs with yours and see what's missing.
Nope I still got the same issue...here's my configs:
Europe:
crypto map RTS 1 set security-association lifetime seconds 28800
crypto map vpntunnel 21 set peer ***public ip of london router****
crypto map vpntunnel 21 set security-association lifetime seconds 28800
isakmp policy 1 encryption 3des
pre-shared-key *
tunnel-group ***** type ipsec-l2l
tunnel-group ***** ipsec-attributes
pre-shared-key *
London:
access-list london permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
crypto map hongkongvpn 5 ipsec-isakmp
crypto map hongkongvpn 5 match address hk
crypto map hongkongvpn 5 set peer ***public ip of europe router***
crypto map hongkongvpn 5 set transform-set london
crypto map hongkongvpn 5 set security-association lifetime seconds 28800 kilobytes 4608000
crypto map hongkongvpn interface outside
isakmp key ******** address ***** netmask 255.255.255.255
When I initiate from Europe...I get this on the europe fw:
Active SA: 1
Total IKE SA: 1
1 IKE Peer: ******
Type : user Role : initiator
Rekey : no State : MM_WAIT_MSG2
but nothing on the london FW, and vice versa. I need to initiate both connections before the tunnel times out to get any connectivity going.
