Cisco 3750 QoS Assistance
May 9th, 2007
Dear Support,
I'm a router QoS person, and am completely lost with Catalyst QoS. Seems to be more wrr/srr rather than class-map and policy-map
Am I missing the point or looking in the wrong place?
Can anyone point me to a guide that shows me the syntax and some examples.
Thanks in advance
I always rate helpful posts.
Regards, Adrian.
Overall Rating: 3.5 (2 ratings)
Jon Marshall Wed, 05/09/2007 - 06:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Adrian
I don't believe the 3750 runs CatOS, only IOS although i could be mistaken.
Attached is a link to QOS configuration for 3750 - IOS based.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a008077444d.html
Jon
sundar.palaniappan Wed, 05/09/2007 - 06:11
  • Green, 3000 points or more
Jon,
I don't think Adrian means CatOS. I believe he meant QOS on Catalyst switches and that of course would be IOS on a 3750.
However, the QOS configuration guide link that your provided is correct.
Adrian,
I agree the QOS format isn't universal across every platform and it does vary with the architecture. As you stated SRR or shaped round robin is the queueing method supported on 3750 switches. There should be plenty of documentation and examples available on CCO for you to configure this feature.
Sundar
aoshea Wed, 05/09/2007 - 06:14
Many thanks for your responses, so its of to learn another cisco language :-)
thanks adrian.
