Does anyone run MRTG and CiscoWorks on the same machine?
rolandshum
I have a Windows 2003 server and Ciscoworks running on it. Was wondering if anyone has encountered any issues loading MRTG on the same machine.
avmabe
Level 3
Level 3
I used to, once upon a time.
Although I will say this... Ditch MRTG!!!! .rrd based tools are so much better and have great front ends written around them. http://www.cacti.net is one.
So yes, you can run them both on the same machine, but if you have ANY old computer laying around you can run cacti or mrtg on it.
Joe Clarke
No, this would be fine provided you use your own web server for MRTG, and do not touch any of the CiscoWorks components.
