CME transcode commands
May 9th, 2007
What is the correlation of the CME command "sdspfarm transcode sessions" related to the "dspfarm transcoder maximum sessions" command? Is there a formula to determine the values? For example, if I use 44 (available resources) for the max sessions command should transcode sessions be the same? The range is 1-128, but no guidelines on what to specify other than the number of transcoding sessions you want to use, and all values are considered valid. Also, would the "Units" command be 1?
drolemc Tue, 05/15/2007 - 06:16
dspfarm transcoder maximum sessions: Specifies the maximum number of transcoding sessions to be supported by the DSP farm. A DSP can support up to four transcoding sessions.
sdspfarm transcode sessions:specify the maximum number of transcoding sessions allowed per Cisco CallManager Express (Cisco CME) router, use the sdspfarm transcode sessions command in telephony-service configuration mode
twissam Thu, 05/17/2007 - 08:22
DSP=4 transcoding sessions!!
How did you get this number?
I beleive it should be 8!!!
Good day
