How to fallback to console login when TACACS server down?
May 9th, 2007
Thanks to all, I appreciate your help!
I have a 4006 CatOS switch running 6.3, I can telnet and authenticate via TACACS servers, how do I make sure I'm able to serial console to the switch in the event IP connectivity to the TACACS servers is lost or the TACACS servers are down? This the AAA config:
#authentication
set authentication login tacacs enable telnet primary
set authentication login tacacs enable http primary
set authentication enable tacacs enable telnet primary
set authentication enable tacacs enable http primary
set authentication login attempt 5 console
#authorization
set authorization exec enable tacacs+ deny console
set authorization exec enable tacacs+ deny telnet
set authorization enable enable tacacs+ deny console
set authorization enable enable tacacs+ deny telnet
set authorization commands enable all tacacs+ deny console
set authorization commands enable all tacacs+ deny telnet
end
jhanna@iveco.com.au Wed, 05/09/2007 - 17:45
If you enter the following lines in, Console access will be made to user local credentials.
set authentication login local enable console
Also create a local user to authenticate with.
set localuser user jsmith password j5m1th privilege 15
The account when you log in will be in enable mode instantly. If you dont want this, and would like the console user to enter an enable password, enter the localuser without privilege 15, and also set AAA to have a enable fall back also. Example below.
set authentication enable local enable console
I see you are using "Attempt 5 console", I would recommend you use lockout. This will allow a user to retry in 15 minutes.
set authentication login lockout 900
Kind Regards.
