BARS Restore
May 9th, 2007
Is the following a supported/approved use of BARS. Customer wants to try a restore using BARS to an already working CallManager publisher, i.e. to revert the server to a state it would have been in for example to weeks previously.
Is this a correct way to use BARS, or does the operating system always need to be re-installed firs, i.e. is it a 'disaster' only tool ?
gogasca Wed, 05/09/2007 - 09:38
  • Green, 3000 points or more
That should work.
It will overwrite SQL DC data
mchandak Wed, 05/09/2007 - 09:49
  • Gold, 750 points or more
never really tested this. Restore should work fine, but one thing that I suspect could come up as an issue would be DBReplication
DANIEL COHEN-LAROQUE Tue, 05/15/2007 - 07:25
used several times BARS this way, including on a production publisher (IP Phones & GW registered on subscriber) without any problems, as long as running on very same SW version and IP address
