Transfer direct to voicemail question
May 9th, 2007
I am using the Cisco IP Phone 7960G for CallManager 4.1(3). As a receptionist, I would like to be able to directly transfer people to voicemail (without waiting for the ext. to ring through) when the callee is unavailable. I do not want to idirect them to the general voicemail, and I direct calls for more than one callee/voicemail box, so don't think the manager/assistant proxy line can work for my needs. Any suggestions? Thank you!
Overall Rating: 4 (2 ratings)
loneale2007 Wed, 05/09/2007 - 12:17
Thank you so much for your help! I couldn't seem to find the right page, so I appreciate you finding it for me.
