Corrupted image
May 9th, 2007
Dears;
Suddenly my router restated .. i can't connect to it through LAN.
I connect using console.. rebooted.
seems the image is corrupted.
i tried to login ROMNMN::
rommon 19 > xmodem -c c3745-ipvoice-mz.123-22.bin
Do not start the sending program yet...
dir: cannot open device "flash:"
WARNING: All existing data in flash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
ERR: Not enough memory to download image
rommon 20 > xmodem -c c3745-ipvoice-mz.123-22.bin
Do you wish to continue? y/n [n]: yes
I can't load the image into flash
Overall Rating: 3 (1 ratings)
Richard Burts Wed, 05/09/2007 - 10:10
Waleed has posted exactly the same question in the LAN Switching and Routing forum where it has received several responses. I suggest that any further discussion be consolidated in the LAN forum.
Rick
