05-09-2007 10:37 AM
Is there a show command or OID I can query to see what model of power supplies are installed in 7500 series rtrs running 12.1(7)E?
It doesn't appear RME 3.5 can rpt on these w/ the detailed device rpt or using cwexport....
Solved! Go to Solution.
05-09-2007 11:02 AM
The ciscoEnvMonSupplyStatusDescr object from the CISCO-ENV-MON-MIB and the show env all command are closest you're going to get. They won't show model number, but they will show the wattage and whether or not the PS is AC or DC.
05-09-2007 11:02 AM
