Question Regarding switchport trunk
Answered Question
May 9th, 2007
All, recently I inherited the switches at our facility. Upon review of the configs, I found this config for a port that is connected to a ISCSI SAN:
switchport access vlan 100
switchport trunk pruning vlan 100
switchport mode access
flowcontrol receive desired
spanning-tree portfast
My question is: Is it incorrect to have "switchport trunk pruning vlan 100" on this interface?
Correct Answer by jahilnt10 about 9 years 11 months ago
no never for access port...
You can remove all settings belongs to trunk port and add
span..tree portfast
Overall Rating: 5 (3 ratings)
Edison Ortiz Wed, 05/09/2007 - 12:12
  • Hall of Fame,
    Founding Member
That port current mode is 'access'. The pruning command is not doing anything at the moment.
If you were to change the command
to
switchport mode trunk
All Vlans will be allowed on this trunk except vlan 100.
You can verify more information on the switchport by typing
show int fa0/0 switchport
replace fa0/0 with the interface and port number.
rwamstutz Wed, 05/09/2007 - 12:19
but, I dont want the port to be a trunk port, if its an end user port, correct? Based on the config, how does the port know to be in trunking mode or access? Should a end user port ever be in trunking mode?
Correct Answer
jahilnt10 Wed, 05/09/2007 - 12:25
span..tree portfast
mohammedmahmoud Wed, 05/09/2007 - 12:26
  • Green, 3000 points or more
You are right, a user port should always be an access port, the "switchport trunk pruning vlan 100" command has no meaning here, and thus it has no effect here.
You only need:
P.S Please see my reply on your other post "Another Question regarding Switchport trunk, mode, and Trunk"
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Edison Ortiz Wed, 05/09/2007 - 12:31
  • Hall of Fame,
    Founding Member
The config you posted clearly says to place the port in 'access' mode with the command
by default, a layer 2 switchport is set to dynamic desirable (3550 use dynamic auto).
Dynamic desirable will trunk automatically if the other devices replies to DTP packets, if it doesn't the port will be set to access mode.
For user connection, you don't need trunking. Access mode is the recommended setting.
