high availability between core router and switches
May 9th, 2007
I have 2 core switches on LAN and main router is connected to one of the switches. I want core router to connect both switches for high availability.
Currently, router ethernet interface has multiple sub-interfaces for different VLANs. Is it possible to have another link between router and other switch without creating loop and maintaining similar fuctions (such as DHCP request, VLAN) as other link.
Edison Ortiz Wed, 05/09/2007 - 12:24
  • Hall of Fame,
    Founding Member
For this to work, I recommend moving all L3 information from the Ethernet interface on the router and placing that information on the core switches, let them perform intervlan routing.
Router on a stick is useful when you don't have L3 switches but from your post, it seems you do.
I don't think the router would allow you to create another LAN interface using IP addresses on the same subnet as the current one.
For instance;
f0/0.1
en do 1
ip add 192.168.1.1 255.255.255.0
int f0/1.1
en do 1
ip add 192.168.1.2 255.255.255.0 (this will fail)
On the core switches, you can do this with SVIs.
On Core 1
int vlan 1
On Core 2
int vlan 1
You can even go as far as creating HSRP between the two by inserting the following commands under each SVI.
standby ip 192.168.1.3
standby priority 110 (Core1)
standby preempt (Core1)
tunemore1 Wed, 05/09/2007 - 13:17
Thanks. Do you have a good link describing SVI?
