2800 series with pots lines, can't call in/out via voip
May 9th, 2007
I have a cisco 2800 series router at a remote site with 4 pots lines in an FXO card, one main number (config below). After a power surge users at that site can no longer dial out from their phones both internally and externally and people cannot call into the main number, users at other sites can complete a call to the affected users. When calling the main number configured on the router it rings with no answer.
trunk group analog
hunt-scheme longest-idle
voice-card 0
no dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
h225 timeout tcp establish 3
class-map match-any Video
match access-group 152
class-map match-any Voice
match ip rtp 16383 16383
match access-group 151
policy-map voice_video_qos
class Video
priority 384
class Voice
priority 768
class class-default
fair-queue
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 192.168.XX.XX 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.XX.XX
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
voice-port 0/1/0
trunk-group analog
no comfort-noise
connection plar XXXXXXX
description XXXXXXXXXX
caller-id enable
voice-port 0/1/1
trunk-group analog
no comfort-noise
caller-id enable
voice-port 0/1/2
trunk-group analog
no comfort-noise
connection plar XXXXXXXXXX
caller-id enable
voice-port 0/1/3
trunk-group analog
no comfort-noise
caller-id enable
dial-peer voice 1 pots
trunkgroup analog
incoming called-number .
direct-inward-dial
dial-peer voice 911 pots
trunkgroup analog
destination-pattern 911
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
forward-digits all
dial-peer voice 411 pots
trunkgroup analog
destination-pattern 411
direct-inward-dial
forward-digits all
dial-peer voice 8888 pots
trunkgroup analog
destination-pattern 8T
direct-inward-dial
dial-peer voice 810 pots
trunkgroup analog
destination-pattern 81..........
direct-inward-dial
forward-digits 11
dial-peer voice 807 pots
trunkgroup analog
destination-pattern 8[2-9]......
direct-inward-dial
dial-peer voice 8411 pots
trunkgroup analog
destination-pattern 8411
direct-inward-dial
forward-digits 3
dial-peer voice 8911 pots
trunkgroup analog
destination-pattern 8911
direct-inward-dial
forward-digits 3
dial-peer voice XXXXXXX voip
description XXXXXXXXXX Main number
destination-pattern XXXXXXX
voice-class codec 1
session target ipv4:10.30.X.XX
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
call-manager-fallback
secondary-dialtone 8
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7910 2
limit-dn 7935 1
limit-dn 7940 2
limit-dn 7960 4
timeouts interdigit 5
timeouts busy 5
timeouts ringing 20
ip source-address 192.168.XX.XX port 2000
max-ephones 30
max-dn 60
access-code pri 8T direct-inward-dial
What may be wrong with this config that would cause these issue(s)?
Is there a way I can find out if it is the FXO card?
Paolo Bevilacqua Wed, 05/09/2007 - 13:58
  • Hall of Fame,
    Founding Member
can you have some plug a regular phone in place of router and see if it rings ?
I haven't really looked at your config but if it was working before there is no reason it should not work now.
kelvin.blair Wed, 05/09/2007 - 19:06
  • Silver, 250 points or more
Do a show log and verify that you do not have any DSP errors. I have seen DSP's go bad after a power surge. Although it?s not a common occurrence, it has happened twice in my case.
jmrosenfeld Thu, 05/10/2007 - 04:17
Thanks, the log shows there are some dsp errors on the lines though I'm not sure exactly what the error means - is it a hardware problem on the router or an issue with the pots lines?
*May 9 19:51:28.247: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 dsp 1.
*May 9 19:51:28.571: %FLEX_DNLD-3-ERROR_FIRMWARE_DNLD: DSP firmware download fails for slot 0 dsp_id 0
*May 9 19:51:39.435: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 dsp 1.
*May 9 19:51:39.763: %FLEX_DNLD-3-ERROR_FIRMWARE_DNLD: DSP firmware download fails for slot 0 dsp_id 0
*May 9 19:51:50.639: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 dsp 1.
*May 9 19:51:50.963: %FLEX_DNLD-3-ERROR_FIRMWARE_DNLD: DSP firmware download fails for slot 0 dsp_id 0
*May 9 19:52:01.831: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 dsp 1.
*May 9 19:52:02.155: %FLEX_DNLD-3-ERROR_FIRMWARE_DNLD: DSP firmware download fails for slot 0 dsp_id 0
I found the following info on the errors:
Explanation An error has occurred during initialization of the DSP in the specified slot with the application firmware.
Recommended Action Power down, reinsert the port module, and reboot. If this message recurs, copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
kelvin.blair Thu, 05/10/2007 - 05:11
The errors look the same as what I was getting. Two things you can do.
The first is to do what the Explanation above stated.
The second is to get anther DSP Firmware and apply to the flash in the router. Reboot the router and let the new firmware download to the DSP.
If both these options do not work, you need to get a RMA on the dsp's they are bad.
jmrosenfeld Thu, 05/10/2007 - 07:25
Go it.
Where can I get the DSP firmware and how is it applied to router? Is this just a normal firmware update?
kelvin.blair Thu, 05/10/2007 - 07:59
You can get dsp firmware from TAC or upgrade the IOS. Generally newer IOS has new dsp firmware builtin
