Modem connects, but I can't type logins
May 9th, 2007
Hello all, I have a router configured for simple modem backup for OOB managment. The modem connects to the router and I see warning banners as well as login prompts. I try to type the login credentials, but nothing shows up and the box gives a timeout error.
line aux 0
exec-timeout 0 0
logging synchronous
login local
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
thanks for any comments,
Chris Serafin
[email protected]
bjornarsb Sat, 05/12/2007 - 10:55
  • Bronze, 100 points or more
You need to figure out speed settings.
Does your aux port support that speed?
If you already have done that .
Try:
(config-line)#login
(config-line)#password cisco
Bjornarsb
bjornarsb Sat, 05/12/2007 - 12:07
Hi again,
You could also try:
(config-line)#autobaud
BR,
Bjornarsb
