Block Youtube.com
May 9th, 2007
I'm trying to block youtube.com using NBAR. I can see on the show policy-map interface that it matches the class-map but the router won't drop the packet. Here's my config.
class-map match-any Class_NBAR
match protocol bittorrent
match protocol gnutella
match protocol kazaa2
match protocol gopher
match protocol napster
match protocol rtp video
match protocol http url "*.youtube.com*"
policy-map Policy_NBAR
class Class_NBAR
drop
interface FastEthernet0/1
ip nbar protocol-discovery
service-policy output Policy_NBAR
Is this a correct configuration? Thanks.
John
Overall Rating: 4 (1 ratings)
Pari Thiagasundaram Wed, 05/09/2007 - 15:10
  • Silver, 250 points or more
You need to enable Cisco Express Forwarding (CEF) in order to use Network-Based Application Recognition (NBAR).
Could you check if it is enabled ?
dbellaze Wed, 05/09/2007 - 15:17
  • Bronze, 100 points or more
It might be easier to do this with an ACL if YouTube only uses their registered IP's. You can go to www.arin.net and find all YouTube's ranges and block those.
NBAR has been a hit and miss for me for certain applications. I also found that just using the drop command wasn't always successful either. Try using the police statement instead and set all the actions to drop that might work for you.
Daniel
John Patrick Lopez Wed, 05/09/2007 - 15:26
I forgot to post this, I am also using rate-limit command on the interface.
rate-limit input 1048000 131072 131072 conform-action transmit exceed-action drop
rate-limit output 1048000 131072 131072 conform-action transmit exceed-action drop
dbellaze Wed, 05/09/2007 - 15:33
You can move your interface rate limiting to the MQC policy.
class class_NBAR
police 8000 conform-ac drop exceed-act drop violate-act drop
class class-default
police 1048000 131072 131072 conform-action transmit exceed-action drop violate-action drop
policy-map Policy_Inbound
class class-default
int fa 0/1
service-policy input Policy_Inbound
Daniel
John Patrick Lopez Wed, 05/09/2007 - 15:48
I can see the conformed packets increment and the action to drop but still the website can pass thru. I already tried setting a DSCP value of 1 awhile ago and drop all output packets using access-list matching a value of 1 in DSCP. Im losing hope right now. By the way, it's a 2600 router.
Pari Thiagasundaram Wed, 05/09/2007 - 15:54
can you change :
to :
class-map match-all Class_NBAR
and check again ?
dbellaze Wed, 05/09/2007 - 15:58
The match-all will require matching all match statements which will not work unless you remove all the other match commands.
I ran into this same problem for gnutella and bitorrent. I got with Cisco and pretty much got no where with it. Your best best for now maybe to just block their ranges or get more clever with what you want to match to try to block it.
Daniel
Pari Thiagasundaram Wed, 05/09/2007 - 16:11
My bad. I couldnt find a "delete" option once i posted it.
Where is fa0/1 connected to ?
John Patrick Lopez Wed, 05/09/2007 - 17:19
I applied it on Fa0/1 as service-policy output. I already tried to apply it in all directions but still the same. I can still access youtube.com.
John Patrick Lopez Thu, 05/10/2007 - 10:15
I tried to monitor the policy-map and there very minimal packets. Do you guys have any other idea on how to do this except for using ACL blocking the IP address of www.youtube.com?
mohammedrafiq Thu, 05/10/2007 - 10:58
Can you try to block this range and then try.
208.65.152.0 - 208.65.155.255
