DHCP server in 877w router
Answered Question
Has any people make it working that configure a DHCP pool to give a fixed IP address to a PC? I have tried a few IOS version. but no luck.
ip dhcp pool kevin-pc
host 192.168.1.100 255.255.255.0
hardware-address 0040.f417.30e6
default-router 192.168.1.1
dns-server 202.27.184.3 202.27.184.5
Correct Answer by Paolo Bevilacqua about 9 years 10 months ago
Actually I do have an 857w and and I can assign static address without a problem:
ip dhcp pool mystatic
host 10.0.97.200 255.255.255.0
client-identifier 0100.0e35.f32c.ac
default-router 10.0.97.1
dns-server 4.2.2.1
Remember that winXP adds a byte "01" in front of the client-identifier, after this byte you have to append the mac-address as above.
Sorry, no reward for finding cisco bugs. If there were, I would be rich now.
Overall Rating: 5 (2 ratings)
Pari Thiagasundaram Wed, 05/09/2007 - 16:21
  • Silver, 250 points or more
Are there any restrictions that you have in your network which would prevent giving a static ip on the PC ?
Pari Thiagasundaram Wed, 05/09/2007 - 16:22
Paolo Bevilacqua Thu, 05/10/2007 - 15:27
  • Hall of Fame,
    Founding Member
What about turning encryption on. Remember that any other method may prevent them to connect, but not receive your traffic.
rajinikanth Wed, 05/09/2007 - 21:18
  • Bronze, 100 points or more
Hi Kevin,
You should use the below keyword after entering MAC addr.
hardware-address 0040.f417.30e6 ieee802
Hope this helps
Raj
nikolay-shopik Thu, 05/10/2007 - 22:10
looks like manual binding is broken - look at this for exmaple.
192.168.10.14 000c.29f3.7a70 May 12 2007 10:02 AM Automatic
192.168.10.100 000c.29f3.7a70 Infinite Manual
it's still geting address from dynamic pool and not static
Correct Answer
Paolo Bevilacqua Fri, 05/11/2007 - 03:47
  • Hall of Fame,
    Founding Member
dns-server 4.2.2.1
