ankbhasi Wed, 05/09/2007 - 20:40
  • Cisco Employee,
Hi Friend,
Switch(config)#service dhcp
Switch(config)#ip dhcp pool
Switch(dhcp-config)#network x.x.x.x
Switch(dhcp-config)#default-router
Switch(config)#ip dhcp excluded-address
You should exclude the address which you want but it is always recommended to exclude atleast the router address which will be assigned to the clients as a gateway address.
You can create multiple pools for different subnets and ip address range.
Ankur
*Pls rate all helpfull post
Anand Narayana Wed, 05/09/2007 - 21:26
  • Silver, 250 points or more
Hi Dall,
find the working configuration.
3560#config
3560(config)#ip dhcp pool ABCD
3560(config-dhcp)#network 192.168.1.0 3560(config-dhcp)#255.255.255.0
3560(config-dhcp)#dns-server 10.2.1.1
3560(config-dhcp)#domain-name abcd.org
3560(config-dhcp)#default-router 192.168.1.254
3560(config-dhcp)#lease infinite
3560(config-dhcp)#exit
3560(config)#ip dhcp-server 192.168.1.254
3560(config)#interface vlan 2
3560(config-if)#ip address 192.168.1.254 255.255.255.0
additionally if u wanted to exclude certain ip address which should not be assigned to client , issue the following command
3560(config)#ip adhcp excluded-address 192.168.1.100 192.168.1.110
which means between 192.168.1.100 & 192.168.1.110 the ip address will not be allocated.
i hope this helps.
rate this post if clear.
