Dial-peer for multiple voice ports
May 9th, 2007
Hello guy,
I want to kwon if there is a way to configure, one dial-peer for multiple FXO voice port to make call to PSTN.
I have a VIC-4FXO and i need to create for Dial.peers for my dial plan
Is there a way to include all FXO port in one Dial-peer to make PSTN Call.
I have a huge list of Dial-peer, i dont want use 9T becase im using Cor List.
Thanks.
Overall Rating: 4.7 (3 ratings)
gogasca Wed, 05/09/2007 - 21:36
  • Green, 3000 points or more
Use trunk-group feature.
Not sure if they work for FXO...
If not use preference option for each dial-peer
paolo bevilacqua Thu, 05/10/2007 - 04:20
  • Hall of Fame,
    Founding Member
Sure, trunk-group will work with FXO.
It will give you:
* simplified configuration
* multiple trunk targets under the same DP
* many options to hunt scheme the lines
* nice statistics.
Better than that, there is only cold beer :)
robert.bernal Thu, 05/17/2007 - 07:03
thanks, i was trying but not working, do you have some example for do it with FXO
paolo bevilacqua Thu, 05/17/2007 - 07:12
  • Hall of Fame,
    Founding Member
voice-port 0/0/0
trunk-group fxo
voice-port 0/0/1
trunk-group fxo
dial-peer voice 100 pots
trunkgroup fxo
This is the minimum. You can also configure "trunk group fxo" in global mode if you want a non-default hunt scheme.
robert.bernal Thu, 05/17/2007 - 07:42
its done, i have now working my peers with trunks, thanks a lot guys.
paolo bevilacqua Thu, 05/17/2007 - 08:00
  • Hall of Fame,
    Founding Member
Glad to know that worked, good luck!
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
