To implement password levels
May 9th, 2007
Hi there,
could someone share information on :
1) How to password privilege level
2) I need to be in enable mode
3) should not be able perform a conf t
4) how do i do this.
5) what is the privilege level
Thank you. Appreciate your info here.
Anand S Thu, 05/10/2007 - 08:25
Hi Devan,
juz issue the following commands, you will achieve what your looking in for.
aaa new-model
username user privilege 1 password xxxx
privilege exec level 1 show
line vty 0 4
privilege level 1
password xxx
u can add the following for a particular user to gain full access.
aaa new-model
username devan privilege 15 password xxxx
privilege exec level 15 conf t
line vty 0 4
privilege level 15
password xxx
lemme know anything else has to clarified.
hope this helps.
rate this post if satisfied.
mohammedmahmoud Thu, 05/10/2007 - 23:33
try this, you can use any of the customer privilege levels (2-14):
enable secret
username test privilege 15 password --> This one is there for safety
username test14 privilege 14 password 7
privilege exec all level 14 show
privilege exec all level 14 ping --> For extended ping, you might need to enter some specific commands
line con 0
login local
line vty 0 4
login local
HTH, please do rate if it does help,
Mohammed Mahmoud.
