FXO to FXS configuration
May 9th, 2007
kindly tell me the configuration of the FXO port in a router(2811). When I connect the exchange line(no7028) to the FXO port and attempt call 7028 from another line(7022) or any other number it is giving a busy signal. I doubt the port configuration.kindly advice
Iam attaching my tech report plz suggest me the best config
srinivas.D
chris.lepa Thu, 05/10/2007 - 10:38
You seem to be missing the port command on the brahmos side.
dial-peer voice 1 pots
destination-pattern .T
(port 1/0/0 or whatever here)
That's a possibility...
