Startup of ASA firewall
Answered Question
May 10th, 2007
Hi all,
How to access ASA firewall via web browser ? It is a new one and I have set the ip address (192.168.1.1) under Management interface. The ASA management port is connected to my notebook (192.168.1.2 ) directly. After that I see the Management port is up but my notebook ping or access ASA (192.168.1.1)
Correct Answer by Anand Narayana about 10 years 2 months ago
if you wanted to access the ASA via web broswer, juz issue the following command.
http 192.168.1.1 255.255.255.255 inside
for telnet
telnet 192.168.1.1 255.255.255.255 inside
by default ASA doesn't allow you to login for accessing it throught http or telnet, you need to specify from which IP,which service via which interface. here in my example. "management" is a interface name, which means connection from "management" interface with the ip address 192.168.1.1 is only allowed rest all IP address are denied.
interface management 0/0
nameif management
security-level 100
ip address 192.168.1.254 255.255.255.0
hope this helps.
rate this post, if satisfied.
Overall Rating: 5 (1 ratings)
Amit Singh Thu, 05/10/2007 - 01:55
  • Cisco Employee,
Please make sure that the HTTP server is enabled for ASDM on ASA. Use the folliwing config.
nameif management
security-level 100
no shutdown
asdm logging informational 100
asdm history enable
http server enable
http 192.168.1.0 255.255.255.0 management
Once that is done :
Access the page by using https://interface_ip_address
HTH,
-amit singh
Correct Answer
Anand Narayana Thu, 05/10/2007 - 02:01
  • Silver, 250 points or more
for telnet
nameif management
security-level 100
hope this helps.
