Enable CEF on ISDN 802 Router
Answered Question
May 10th, 2007
I'm trying to enable CEF on 802 ISDN router but cannot find the command?
Correct Answer by mohammedmahmoud about 10 years 2 months ago
hi,
Unfortunately, it seems that the 802 doesn't support CEF.
Always use "Cisco Feature Navigator":
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
mohammedmahmoud Thu, 05/10/2007 - 02:16
  • Green, 3000 points or more
use "ip cef" in the global configuration.
What is your IOS, please do "show ver" ?
Mohammed Mahmoud.
mdcarey15 Thu, 05/10/2007 - 02:19
ip cef does not work
I'm running 12.1(3)XG5 and 12.2(37) on the routers.
I'm trying to add the command, "ip verify unicast reverse-path" and it tells me to enable CEF first, so it this IOS must support it
router(config-if)#ip veri u r
% CEF not enabled. Enable first
router(config)#ip cef
% Invalid input detected at '^' marker.
