RA VPN Error
May 10th, 2007
Hi Gents,
I have configured 2xRA VPN connections.
ip local pool inside_pool 10.10.105.1-10.10.105.254 mask 255.255.255.0
ip local pool dmz_pool 10.10.104.1-10.10.104.254 mask 255.255.255.0
I have acl restrictions for both pool. Inside_pool has access to inside network:
for instance 10.20.1.0/24
It is working fine.
DMZ_pool has access to dmz servers.
But it doesn't work.
I can manage connecting by RA VPN(dmz_pool). But i can't reach the servers in DMZ. I saw in logs that "no translation group found for outside ip 10.10.104.1 "
Is it normal that ASA asking me about NAT configuration for OUTSIDE?
I do the same for inside_pool, except that access goes to inside interface,not to dmz interface.It is working fine without any nat translation requirements.
Any comments will be appreciated.
Leo
mfreijser Thu, 05/10/2007 - 03:18
  • Bronze, 100 points or more
A nonat access-list from the DMZ to the OUTSIDE should do the trick:
access-list nonat_dmz permit ip 10.10.104.0 255.255.255.0
nat (dmz) 0 access-list nonat_dmz
Note that this will no affect any statics already created for the DMZ-subnet!
Please rate if the post helps!
Michael
