Privilege Level command
Answered Question
May 10th, 2007
  • Silver, 250 points or more
this is my working configuration in my Cisco 1751 router, with this i can directly login to the router with full access to it, without accessing for "enable password", ie.
username: anand
password: xxxx
1751#
username anand privilege 15 password xxxx
privilege exec level 15 configure terminal
line vty 0 4
privilege level 15
the same kind of thing i wanted to configure in my Pix/ASA, can you help me out in this.also i wanted a privliged level 1 user should not a enter in to "enable" mode, the "enable" command should get denied.
Correct Answer by royalblues about 9 years 11 months ago
anand,
I don think you can directly telnet/ssh with a privilege level 15 to a pix or the asa.
You always enter the user mode even when you are using ACS with shell authorization
Narayan
Overall Rating: 2 (1 ratings)
Correct Answer
royalblues Thu, 05/10/2007 - 11:44
  • Green, 3000 points or more
anand,
Narayan
Anand Narayana Thu, 05/10/2007 - 20:41
Thanks Narayan. infact b4 posting this, i went & searched documents related to this, but couldn't succeed, that is why thought of post in this, any thanks once again.
