How to configure a new interface on a router
May 10th, 2007
I hope someone can help me. I've got a 3640 router that has the following config
interface FastEthernet0/0
ip address
no ip redirects
ip route-cache same-interface
ip route-cache flow
no ip mroute-cache
speed 100
standby 1 timers 5 15
standby 1 preempt
standby 1 authentication xxxxx
standby 1 ip
interface FastEthernet0/1
ip address
no ip redirects
ip route-cache flow
speed 100
router ospf 1
redistribute connected subnets route-map PRIVONLY
redistribute static subnets
redistribute rip metric 120
network area 0
network area 0
network area 0
default-information originate
router rip
version 2
redistribute ospf 1
default-metric 30
What I'd like to do is create a new VLAN on the same connection that is coming off of fa 0/0 so instead of just I want to have a
My question is how can I change the above config to accomodate a new vlan? I think I need to create subinterfaces, but I was worried about what it might affect given the above config. Also on the switch port do I need to convert the port to a trunk link?
Thanks in advance
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 05/10/2007 - 04:06
Hi Dan
Yes you will need to use subinterfaces and the switchport will need to be a trunk port.
For arguments sake let say is vlan 10 is vlan 20
int fa0/0.10
encapsulation dot1q 10
ip address
+ other config you have
int fa0/0.20
encapsulation dot1q 20
ip address 10.32.x.x
+ additonal config you need
As alreay said you need to convert your switchport to a trunk port.
